-   -   talari (http://www.mariahownersclub.com/forum/original-mariah-talk/11764-talari.html)
wuffie 09-01-2017 10:34 AM
talari
Recently purchased a 94 Talari and it has what looks like a little lcd screen with a circuit board behind it. It is located near the radio near the shifter . Mine doesn't work . Was wondering what it is and what it does. Thanks
tbrookens 09-01-2017 04:12 PM
Re: talari
Mine shows water temp and air temp, depending on the position of the switch next to it.
Abrahwany 11-21-2020 01:39 PM
Re: talari
I think you need a new PCB that will make everything work well. Usually these are installed to show the temperature, a pretty ncie thing to be honest. I had the same thing and I needed to change the pcb in order to make it work again because it was eaten by salt somehow. It didn't took me too much for understanding circuit boards. I read a little bit more about this and repaired it by myself, it is very interesting. Now, it works very well and I am very thankful that I learn everything with the help of one guide.
