Repair or service manual
Hi, more of an inquiry, is there such a thing as a repair manual on the Talari Z200? Not just the motor, but on the whole boat? Thanks
Re: Repair or service manual
Not that I know of. The accessories manuals are in the member's section. What are you looking to repair?
Sent from my SM-G900V using Tapatalk |
That's what I thought. My hatch lifts are not working and I wanted to see a wiring diagram before I just "figure it out", so I thought I'd try to find a full service manual first. There's some other things I'd like to look at also which the manual may have helped with. I just got the boat and fixing up a few things. Thanks
I replaced my linear actuator last year. You can get the wiring harness diagrams in the contributing members area. I ended up making a switch box next to the bench seat and wired it in from there. That way you could lift the hatch while you were at the rear bench verse drivers seat
Lots of great info and people here. For all your project needs. Been doing the same with mine since I bought it last spring
That's a good idea, the console with the stereo etc down by your right shin shattered when I was towing it home so I'm rebuilding it out of aluminum instead of plastic, and I have new switches so maybe I'll look to do the same, thanks for the suggestion. And I'll check the section and see what I can find. Thanks again for the info
How did you know one of my winter projects. Put a new steroids in and mine is just crumbling apart.
| All times are GMT. The time now is 05:17 PM. |
