-   -   Bow rail removal (http://www.mariahownersclub.com/forum/original-mariah-talk/11540-bow-rail-removal.html)
Grimm 06-14-2017 01:24 AM
Bow rail removal
2 Attachment(s)
I bought my 91 MX20 last fall and always hated the look of the tall bow rail that was installed by a previous owner. Also, I truly don't see the benefit of having such a large bow rail either.
While driving the boat this past weekend, I got tired of staring at the rail while sitting in the cockpit, it made the boat feel like the bow was pointing up at the sky all the time. I finally came to the conclusion that the rail had to come off.
A little knuckle busting here and there and the rail popped right off. I capped the holes with silicone and white push darts, not perfect, but it looks pretty good. Plus, if I later decide to reinstall the old bow rail, that option is always there. In the future, I might install a low profile bow rail, or maybe a pair that run parallel to each other mounted on each side of the cuddy hatch.
Here's a pair of before and after pics. Let me know what you think.
iced98lx 06-14-2017 01:26 AM
Re: Bow rail removal
Good choice!! Looks good
Sent from my XT1575 using Tapatalk
Firestone 06-14-2017 01:50 AM
I like it as well. Has a clean look to it.
chuse927 06-14-2017 10:53 AM
Much better. I agree a low profile rail would look better.
Sent from my SM-N920V using Tapatalk
bibleg2015 06-16-2017 11:07 PM
Looks good, clean and smooth.
GaryDoug 06-18-2017 02:01 AM
You probably already know this... but from now until you reinstall a new bow rail, you must not allow anyone to ride on the front of the boat while it is motion. It is a federal offense to allow any one to ride on the front unless there is a recessed area for seating or a bow rail. Even dropping or retrieving an anchor while moving is forbidden. There are workarounds for that case, like having a retrieval line from the anchor line to the cockpit. I was ignorantly guilty of that infraction many years back and was lectured by a federal law officer on the subject.
p.s. I don't see that bow rail as being very high. The one on my sailboat is much higher. Also, I think that a bow rail was standard equipment.
More: After searching online I can't find any information on the federal laws on this. But it looks like the states may have taken over the responsibilities. In Florida for example, even a bow rail isn't enough to allow bow riding. You may want to check your state's laws on this.
Grimm 06-18-2017 01:02 PM
Appreciate the advice GaryDoug. I will look into the legality issue of riding on top. I'm not against installing a low profile bow rail, just that this one was too high for my liking. In fact, while polishing my boat after the removal of the rail, I came across a couple of patched holes where the original bow rail was mounted. I thought that it was odd that I never could find a pic of my bow rail in the original documentation and now I know why.
Grimm 06-22-2017 01:07 AM
3 Attachment(s)
Looking at constructing a new set of bow rails, I realized the expense of new rails are quite costly. I considered an alternative was a pair of safety grab bars for a bathroom. I came across a smoking deal on Amazon for a stainless pair for only $40. I did know ahead of the game that the bar diameter was 1 1/4", but in reality it was 1 1/2". After dry fitting them, I feel that the bars are too fat to look decent, so I'll hold out until I come across a deal on a real set of rails with 7/8" diameter.
Here's what the large bars would have looked like. Again, I'm not going to install these.
Firestone 06-22-2017 01:13 AM
Can you modify your old ones to give you the look you want?
chuse927 06-22-2017 01:27 AM
Yeah those don't look good. 😎
