Heat Soak???
On the lake now 4th trip out.
Freshly rebuilt 1994 7.4l Mercruiser 7 hours on engine Runs perfectly fine, but noticed tonight that when I go to start boat the temp gauge is at 175-180. Port side riser 210 degrees after 10 minute soak Starboard 190 degrees after 10 minute soak A little online research suggested idling for 30 seconds prior to shutting down. Initial check showed temps below. Port side 130 Starboard 130 With in 5 minutes the portside riser is 200 degrees Starboard 150. I can hear some gurgling after shutting down. Any suggestions?? |
Re: Heat Soak???
Valve covers 160
Oil filter 165 Exhaust manifolds 200 each Thermostat housing 155 Shooting IR on everything now!! |
Re: Heat Soak???
[QUOTE=juttmk;62530]Valve covers 160
Oil itfguuvnw fbj 165 Exhaust manifolds 200 each hgefg Thermostat housing u Shooting IR on everything now! |
| All times are GMT. The time now is 08:26 PM. |
