speed and rpm
Im a new Mariah owner and im having a few issues. Let me start by saying I own a 96 210 shabah with 5.7 liter 1.62 alpha one drive, 21 pitch 4 blade prop. My problem is At wot im getting about 47 mph at 4100 rpms. I think the specs call for a 21 pitch, which should give me 4500 to 4800. any suggestions? Thanks
Let us know how you make out?? If it turns out to be a prop issue you could punch the info you have into Merc's prop selector tool at: https://appcenter.mercurymarine.com/...lector/home.do I had a quick look and it shows a 3 blade, 13.75" x 23 pitch or a 4 blade, 14" x 23pitch ss prop as ideal for overall performance. Increasing the pitch to 23 should lower your rpm by 200 or so but make sure the tach's working properly first. |
I am a new owner and am working with the shop were I bought the boat.
Similar issue as above. I am running a 454 in a 1994 Mariah Talari z220 with a Bravo I. The prop and pitch get me to 57 mph but the rpm's go to 5400 and the rpm regulator will shut the engine down to stop any potential damage... any suggestions or does anyone know what the proper pitch and number of blades is recommended? I believe the boat should do around 63 to 65 mph. It ran with the above numbers on a five blade with a pitch of 25 I believe??? - but I could be mixing that up with the three blade prop we tried which did nothing but spin out. The other thing I heard was I may not get the maximum speed but my hole shot is greater with the five blade as opposed to a three blade. Any suggestions, specifications or comments on the above situation would be a great help. Thanks. |
Go ahead and give Mikey's suggestion a go, if it fixes your problem great, if not, could you provide us with some more info? 1) What is the diameter of your current prop? 2) Carbed or fuel injected motor and it's HP rating? 3) How many people are on board and can you give us a guesstimate on their combined weight 4) How much gas was in the boat 5) Did you have any extra ear? If yes, weight? 6) Are you trimming the hull correctly? From what your saying, I suspect your motor is over propped. Let us know, WetWilly |
Hey Mariahz220Talari,
Your right about the top speed (low to mid sixties) and remember, the more blades, the better the holeshot but lower top end. To figure out your problem, we need to know what prop your having trouble with. Sort out the prop mix up (is it the five bladder or three bladder and what is the pitch of both props) and get back to us and we'll get you back on track. WetWilly |
They are picking up the boat and going to try some different props including plugging the exhaust ports on the three blade (not sure what pitch that one is). That is all I've got right now. |
| All times are GMT. The time now is 01:19 AM. |
