Hour meter Help
I have a 2000 Z252 Shabah with the 7.4 Mag MPI & the Bravo3 drive Hour meter not working need help wiring diagram. How can I find out how many hours are really on it
Re: Hour meter Help
The Faria electro mechanical hour meters that came with our boats are just two wire devices. One wire goes to the keyswitch and the other to ground.
If you want to know exactly how many hours are on your 7.4MPI then you will need to hook up a scanner to the ECU. Your local mechanic should be able to help you out with this. |
| All times are GMT. The time now is 10:30 AM. |
