-   -   Steering cable (http://www.mariahownersclub.com/forum/original-mariah-talk/11297-steering-cable.html)
MAtt4177 03-01-2017 06:30 PM
2001 192 Shabah Steering cable
I have a 2001 192 Shabah that is very hard to steer. Does anyone have experience replacing the steering cable?
MTH 03-01-2017 09:13 PM
Re: Steering cable
Does it feel like slack in the steering linkage?
MAtt4177 03-01-2017 09:14 PM
Re: Steering cable
No slack .
MAtt4177 03-01-2017 09:16 PM
Re: Steering cable
really hard to turn the wheel at low speed and doesnt get much better going faster.
Hudson River Steve 03-02-2017 12:39 PM
Re: 2001 192 Shabah Steering cable
How do you know it is the steering cable? Are you sure the power steering, particularly the control valve is operating correctly?
MAtt4177 03-02-2017 12:44 PM
Re: Steering cable
I am not sure of what the problem is really. I drove the boat alot last summer in hopes that it would loosen up with use, but it did not and i dont want to struggle with it this summer. I am just beginning to explore my best options of repair...
Hudson River Steve 03-02-2017 12:49 PM
You can isolate the cable from the steering tiller with a single bolt and try running the cable back and forth. If it still feels stiff then the problem is the cable. If it feels free the the problem is in the power steering system which can be a stuck control valve or the pump itself. I assume you have checked power steering fluid level.
MAtt4177 03-02-2017 12:57 PM
Re: Steering cable
Power steering fluid level good. Thank you so much for the advise on checking the cable. Will be checking this over the weekend !!
