1998 252 shabah, Alt question.
Old 08-23-2016, 09:02 PM   #11
My Model: Z276
Send Brian Belcher:
Default Re: 1998 252 shabah, Alt question.
Have u cleared the hole for the speedo on the outdrive? Is the small, rubber hose still connected from the transom mount to the out drive?
  • Old 08-24-2016, 12:26 AM   #12
    muzzleflash120mm is currently offline
    My Model: Z252 Shabah
    My Engine: 7.4 MPI Bravo III
    Send muzzleflash120mm:
    not sure of either, I will be going to the dock tomorrow to look that all over (boats in the water till late fall. its sitting on a lift, but I have to add a tank to the lift.)
    Z252 Shabah BR 7.4 MPI Bravo III
    Thank you muzzleflash120mm for this useful post!
    pllevine (08-25-2016)
    Old 08-24-2016, 02:08 AM   #13
    My Model: Z276
    Send Brian Belcher:
    You may know all this but someone else who doesn't may learn something.
    On the out drive, if you were to draw an imaginary line, inline with the props shaft, there is a small hole on the front of the drive, opposite the prop and in line with the prop shaft. Take a 1'8" drill bit and BY HAND, NOT WITH A DRILL!!, hand drill the hole and make sure it is clear. The hole turns upwards and comes to a plastic fitting, yellow or blue, that a small rubber hose connects to. That hose goes up into the transom mount and eventual ends up at the speedo.
    That plastic fitting is going to be very brittle if it is still there. It is a quarter turn fitting and if you decide to take it off to make sure the hole is clear, I'd go ahead and get a new one on hand so if it breaks, you have the fix.
    I did this all to mine and I was shocked at how accurate it is or shocked at how inaccurate the GPS is cause they are in sync !
    I've owned MANY big boats over the last 30 years and all of them had the pitot (?) tube and sucked. They eventually came out with the paddle wheel but you had to have a Garmin graph, which I didn't.
    So, I've over stayed my welcome again and good luck with the speedo !
    muzzleflash120mm likes this.
    Old 08-24-2016, 04:05 AM   #14
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    You're right, Brian. That is exactly how I fixed my inop speedo. Using the 1/8" bit by hand and all..... And the results can be seen in the photo:
    1998 202 Shabah 5.0L Alpha 1
    Phil Levine
    1998 202 Shabah
    Old 08-24-2016, 05:24 AM   #15
    My Model: Z276
    Send Brian Belcher:
    Dude.... Is that a dead body in the bow? Looking for a place to dispose of it ? Are you with the DNC ?
    Old 08-24-2016, 05:32 AM   #16
    pllevine's Avatar
    Send pllevine:
    ROFL..... That's my 17 year old son.... I told him that he needed to take the Florida Boating Safety course before I would let him drive the 202 again. So he was sulking in the bow.... The St John's River is mostly all Manatee Zone and/or No Wake zones... That explains the 25 MPH (Manatee Zone)... So the ride was rather slow and boring for him.
    And I am a far cry from being a DNC member....
    Phil Levine
    1998 202 Shabah
    Old 08-24-2016, 03:42 PM   #17
    you guys are Hilarious... Thank you Brian. I did not know how to fix the speedo. hopefully now i do and can get it going. Pellevine? St. Johns River? I grew up on that river, my Dad was Navy and built up a boat to use as a shrimping trawl for a side job. he ended up making more money selling shrimp, fish and crab than what the Navy was paying him. good time's..
    Old 08-24-2016, 07:33 PM   #18
    My Model: Z276
    Send Brian Belcher:
    How ironic.
    I'm an Orange Park swamp rat ! I played football against coach Leonard Skinard (?). Was he a Skinner from the milk and dairy family? And no, I didn't know any of the Van Zants but I did ride my skateboard to the funeral beside the Orange Park mall.
    We lived on Drs Lake.
    Man, I miss that life. The river, swamps, sea cows and gators.
    Old 08-25-2016, 04:43 AM   #19
    pllevine's Avatar
    Send pllevine:
    Default 1998 252 shabah, Alt question.
    Brian... You guys were up at the north end of the river. I'm down here by Lake Jesup/Lake Monroe. For those of you Florida Geography Challenged.... That's a little northeast of Orlando.
    I won't complain about the river speed limits... I don't need to winterize and my boating season is ten months long. I can also take the trip upriver to Jacksonville and run down the Atlantic coast. Even thought about visiting Cuba but not sure as to how safe that would be.....
    The only issue here is how big the bugs are.... I found this spider building a web by my boat and I think he was putting up a toll booth......
    Phil Levine
    1998 202 Shabah
    1998 Shabah 180 Jpattison27 Original Mariah Talk 2 06-29-2016 03:21 AM
    1998 Z 202 Shabah 4BlueWater Mariah Boats For Sale & Wanted 0 06-27-2014 08:53 PM
    1998 Mariah Question Serenity205 Introductions 8 08-12-2010 03:11 PM
    1998 202 Shabah jjk61083 Introductions 3 06-15-2010 02:13 AM
    182 Shabah 1998 ktmbrock Original Mariah Talk 4 06-13-2010 06:03 PM
    Total Members: 18,520
    Total Threads: 12,955
    There are 163 users
