Re: Carbs are good for you
Shabah93, not be confused with Shabah280,AGAIN, did you go with the JR Marine gimbal repair? I'm doing that the middle of next month. If you are, let me know if there is room to double seal the gimbal pin. If not, could you mic out the OD and ID of the seal and maybe a picture of the area where the seal mounts. I will find a double lipped seal if there is enough room or may put two seals if there is enough of seating surface.
If I can double seal, I'll put EP grease in between the two seals for a better seal. Old trick for fixing the leaking Dana60 front ends on our rockcrawlers. |
| All times are GMT. The time now is 03:33 AM. |
