-   -   Toggle switches won't work (http://www.mariahownersclub.com/forum/original-mariah-talk/10713-toggle-switches-wont-work.html)
Unknownmariah 04-24-2016 02:30 AM
I have a 1994 Talari and my seat adjustment, engine hatch and stereo won't work. I think I've blown a fuse but can't find the fuse for it. I've located three right under the dash on left side and changed all three fuses and no luck. Any ideas??
Txtruckerpaul 04-29-2016 10:08 PM
Re: Toggle switches won't work
Check the spade connections where the wires plug into the fuse holder. Those are bad about corrosion and had the same problem with mine. I used a test light and checked all connections that go from the fuse panel all the way back to the battery. My 96 talaria also has a breaker panel on the side walk under the dash that had some corroded connections there, too
