-   -   1995 talari 210 (http://www.mariahownersclub.com/forum/original-mariah-talk/10478-1995-talari-210-a.html)
flt1vfs 09-08-2015 02:17 AM
1995 talari 210
Hello
My talari is very hard to steer.
I understand it is most likely the steering cable.
Anyway to lube this cable?
Does anyone know what size and brand I should get?
How hard to replace?
mikeyt 09-08-2015 03:03 AM
Re: 1995 talari 210
If you were a 'contributing member' you would have access to the manuals that explain how to do this but... there is a lube port at the back but... usually it doesn't help much if at all and you simply need to replace the steering cable.
You could also use the Search Function (upper right corner of the screen) and search for 'hard steering'. You'll find a number of threads discussing that subject.
