Ignition switch
2000 Shabah 182--ignition switch failed. Is the switch a common marine switch, or is it exclusive to the Mariah?
Re: Ignition switch
It should be a common part although from what I've heard the Mariah key blanks are no longer available. But any marine grade ignition switch should function perfectly as long as it has the same positions (off, acc, run, start were the 4 on both of my Mariahs).
Re: Ignition switch
Thanks--that's the information I needed.
Re: Ignition switch
Mariah Ignition switch
4 position Accessory – Off – On – Start Sierra MP41040 Try Gander Mtn for $14.99 Yellow with red stripe - (S) (starter Solenoid) Purple - (I) (ignition) Small Red and Purple (two wires) - (A) (Accessory) Big Red - (B) (battery) |
Re: Ignition switch
Thanks dbrim...I think I'll buy another one for a spare!
Re: Ignition switch
I found the actual switched and keys ! There is a letter code stamped on the key and that's all he needs. If interested, I'll post it up after my wife gets home. She has his contact info.
Re: Ignition switch
Please post when you have time!
Sent from my SM-G900V using Tapatalk |
Re: Ignition switch
iginal Mariah Logo Keys & Key Cylinders - Ordering information
I have the original Gold Mariah keys and matching key cylinders. The keys have a W,X,Y or Z stamped on them for the code. If you cannot find the code then simply hold your key up against the picture below & match the cut pattern. If nothing matches then you very likely have an aftermarket key cylinder/key. If so sent me an email & i will help you out. I do have all 4 of the Original Mariah keys W, X, Y and Z. If you have the plain brass key: W = RL320, X = RL321, Y = RL322, Z = RL323. Original keys are $20.00 each, key cylinders are $30.00 & shipping is $10.00 within the USA & may be slightly more ($18 to Canada) outside of the USA. Prices are still in effect as of Jan 01/14. PayPal at [email protected] and I will ship to your confirmed shipping address. If you have any other questions please email me at: [email protected] Kennedy Marine #210 - 8th Street NW Cedar Rapids, IA. 52405 ph# (319) 366-2896 Attached Thumbnails Original Mariah Logo Keys & Key Cylinders - Ordering information-mariah-keys.jpg Original Mariah Logo Keys & Key Cylinders - Ordering information-chuggins.png |
| All times are GMT. The time now is 11:22 AM. |
