| WetWilly |
04-24-2008 04:40 PM |
Hi 01DiabloMissouri,
Can you tell us the make and model of your throttle? A picture would be better...
Anyway, I'll take a stab at this, it is possible your looking at the engine kill switch.
If not then try this - bring the out drive all the way up with the up trim button. When it stops, continue to hold the up trim button and then press this other button to see if you drive continues upwards, if it does, you've found your trailer switch.
Some units require pushing both the up trim and trailer buttons to raise the out drive to trailer position but only the down trim is required to drop it.
