Mercruiser 4.3 "Fogging"
Old 10-27-2014, 06:23 PM   #1
kriswd40 is currently offline
My Model: Diablo
My Engine: 4.3 Mercury
Send kriswd40:
Default Mercruiser 4.3 "Fogging"
I've owned my 2001 Mariah Diablo for 3 years and am doing my first winterizing myself (since the local shop is very expensive). I think I understand most of the process but I'm unclear on the "fogging" step and if its even necessary.
The engine in my boat is a 4.3 Mercruiser with fuel injection. Fogging as I understand it is something required to do for carbureted engines, although there may be something else done to fuel injected engines that is commonly referred to as fogging but isn't really fogging.
I've been reading up a lot but I'm confused as to the process and if its even required. Some people say to remove spark plugs and spray fogging spray into the block or into the throttlebody, others say I need to create some kind of mixture and run that through my engine, while others are saying you don't need to do anything on 4 stroke engines (which I'm assuming mine is).
Obviously I'll be adding fuel treatment into the fuel before letting it sit, but can someone let me know what (if anything) else I need to do for this "fogging" step? Thanks!
  • Old 10-27-2014, 06:57 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Mercruiser 4.3 "Fogging"
    Mercruiser recommends replacing the fuel filter, filling the new filter with fuel leaving a small amount of room to add 2 oz of 2 stroke oil and then reinstall. Run the engine for a few seconds until you see smoke coming out the exhaust.
    I have also used a can of spray fogging oil with a straw attached to it. Remove the flame arreastor, the throttle plate has a small hole in it that I snake the straw into. Start the engine and idle while spraying the fogging oil for ~30 seconds.
    In both cases you want to coat all the interior surfaces of the combustion chamber, valves etc with oil to slow down corroision/rust.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 11-07-2014, 07:42 PM   #3
    My Model: Diablo
    Send kriswd40:
    Thanks, seems simple enough.
    Ultra Rare 1993 "The Mick" Mariah Z2000 up for Auction ShabahZ280 Mariah Boats For Sale & Wanted 10 07-01-2013 06:03 PM
    Mercruiser "Customer Service" jchemotti Chit Chat/Off-Topic 3 10-24-2012 04:32 AM
    The official "What's your favorite original Mariah accessory" thread! stereoman405 Original Mariah Talk 23 11-10-2011 05:04 PM
    Stainless Steel "Cleaver" Style Prop Question. rktect29 Prop Talk 2 09-16-2010 08:34 PM
    Total Members: 18,518
    Total Threads: 12,955
    There are 182 users
