99 Mercruiser 7.4 won't start Starter Issue's ??????
1 Attachment(s)
Hello everybody,
Was out yesterday and I stopped a couple times and all was good. Stopped at a local picnic island and then she wouldn't start. Battery's are charged . I'm guessing it's the starter but does anybody know if a fuse or trip that would cause this? Only good news was I broke down next to a Tow Boat USA port and they were there in 5 min and pulled me in to my marina. |
Re: 99 Mercruiser 7.4 won't start Starter Issue's ??????
Need a little more information. Did the motor crank and not start or no crank at all? If the later then I assume you checked that the shifter was in neutral. Did you check the starter slave solenoid?
Couldn't check the starter because I couldn't see it. The starter makes no noise at all and the batteries are charged.....the 3 beeps come on with ignition in on position.
I am not aware of beep codes on a 1999 7.4 MPI. My understanding is that you get a 2 sec beep at power on and if anything is wrong (Over Temp, Low Oil Press, Low Drive Oil Level) then is beeps continuous. Did you check your circuit breaker, red button on the engine near the big engine connector to see if it tripped?
Changed the starter and all the leads going to the starter ... Cleaned all connections to batteries and still wouldn't turn....pulled out the ignition switch and fiddled with it a little and she finally fired up..... Now I'm just going to replace the ignition switch.
Can I use any generic 4 position switch from west marine.... Thanks |
1 Attachment(s)
Check out my old starter.. |
| All times are GMT. The time now is 04:17 AM. |
