Mercruiser questions
3 Attachment(s)
I joined this forum as I am restoring an older sports cruiser from 1997, sorry to say not a Mariah but the questions I need to ask can probably be answered by those knowledgeable about Mercury engines and boat equipment in general.
I will attach three photographs in order to explain what I am talking about. See the attached thumbnails. The first question is this: the 12 V hydraulic trim pump is missing from my boat. However I noticed that one of the Mercruiser 502 cu in engines (there are two of those, 1997 models, fitted with Bravo 2 stern drives) seems to have a power pump unit fitted to it, similar to what a power steering unit on a car engine looks like. Is it possible for me to use this unit instead of the original hydraulic trim pump? I know it would only work when the engine is running, of course. If this is not a hydraulic pump assembly, then what is it? The belt to it can be seen hanging loose. The next question I want to ask is this, observing the photograph of a stainless steel tank or container, and a close up of the top lid, what I want to ask, is this the hydraulic fluid unit for the power trim of the stern drives? Any information much appreciated. Thank you. |
Re: Mercruiser questions
As far as I know, the power steering looking pump is just that, used for power steering. That tank looks like it could be a reservoir for a trim system. I'm curious what's under the part that you took a close up of? A pump possibly? Shot in the dark, but could it be the trim pump is submerged in that tank?
| All times are GMT. The time now is 06:14 PM. |
