problem with Mercruiser 5.0 MPI
Old 08-07-2012, 11:47 AM   #11
TomasSE is currently offline
My Year: 2008
My Model: SC25
My Engine: 5.0L Bravo III
Send TomasSE:
Default Re: problem with Mercruiser 5.0 MPI
I ordered Rind diagnostic tool, I have it at home now, everything works.
But I have another problem. I was diagnosed I found the engine and four active faults:
130 Trim CCT HI
75 Fuel Hi LVL CKT
94 Pitot CKT LO
22 HORN OUTPUT (OUTPUT Horn is inactive now, I disconnected the horn on purpose so I could go on. Horn is working now.)
In memory I uploaded my fault, inactive faults:
153 LOW DRIVE LUBE
210 OVER NEUTRAL SPE
19 OVER SPEED
21 ECT OVRHT
151 FUEL PUMP RLICK
121 TRI 1 CKT LO
I deleted all defects, but the alarm still Sirens incessantly.
When you load an active fault appears to me
130 Trim CCT HI
75 Fuel Hi LVL CKT
94 Pitot CKT LO
The Z-drive oil is OK now, engine lubrication functions to the specified pressure, engine cooling OK to the specified temperature, according to the diagnostic engine runs at 100% power.
When you load fault time and fault duration is only: warning horn. Another fault diagnostics did not load.
Does anyone have any idea why it still Sirens alarm when there are no other errors?
Also I do not know why the fuel pump after turning the ignition is running continuously. Previously ran only 2 seconds and then stopped running.
Thanks for any advice.
    Mercruiser 5.0 EFI engine problem timgordon Mercury MerCruiser 4 09-13-2011 01:22 PM
    Mercruiser 5.7L Q's dabates Original Mariah Talk 4 07-11-2011 03:05 PM
    mercruiser 5.7 problem Brownboy Boating 101 3 10-13-2010 04:03 AM
    Mercruiser 454 Magnum markkearns Mercury MerCruiser 2 07-08-2009 05:25 PM
    5.7 L Mercruiser 300sflyer Mercury MerCruiser 8 07-29-2008 04:42 PM
    There are 352 users
