1996 Mariah 5.7
Old 01-15-2012, 07:35 PM   #1
brn2rase is currently offline
My Model: 201 Talari
My Engine: 5.7 Bravo 3
Send brn2rase:
Default 1996 Mariah 5.7
I have a 1996 with a 5.7 engine with a plastic front timming cover. The engine is bad can i replace it with one out of a 1996 chevy P/U with a metal front cover?
  • Old 01-15-2012, 10:12 PM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: 1996 Mariah 5.7
    Im not an engine expert, they will likely confirm that the rotation is opposite though.
    I think you will find it wise and mandatory to stick with marine parts since there are many differences in the marine quality of the powertrain system.
    Zack
    1994 Z212 Shabah
    Old 01-15-2012, 10:22 PM   #3
    I would stick with a marine engine.
    Old 01-17-2012, 08:02 PM   #4
    Marine engine. All the components are marine grade, and one of the most important characteristics of marine engines are they are manufactured specifically with things like spark arrestors, flameproof parts, rust and corrosion inhibitors, and they're designed to work without causing any trouble in closed areas like engine compartments, where vapors and fumes can build up. One crank with an auto engine that causes a spark, and this could be you (see below)..... IF you're lucky enough to get away before it explodes.
    Yes, Marine engines are more expensive. But there's a reason why. Don't cheap out if you value you and your passengers safety.
    1996 Mariah Mariah on the bay Introductions 2 06-29-2011 03:26 AM
    1996 mariah talari 215 difran25 Original Mariah Talk 2 06-02-2009 04:06 AM
    1996 Mariah Talari 215 180diablo Mariah Boats For Sale & Wanted 2 06-03-2008 03:29 PM
    Total Members: 18,994
    Total Threads: 13,325
    There are 363 users
