-   -   engine just revs when in gear (http://www.mariahownersclub.com/forum/mercury-mercruiser/5820-engine-just-revs-when-gear.html)
zzzino1 07-09-2011 09:20 PM
My 1999 Shabbah Mercruiser 4.3 V-6, 190 HP went over some low areasa and now just revs when I throttle up in both forward and reverse. There is just enough prop thrust at idle to get up to 2-3MPH. Nothing else asppears to be wrong .
Any ideas? Spun prop maybe?
IowaWing 07-11-2011 02:37 AM
Re: engine just revs when in gear
That would be my guess.
ShabahZ280 07-11-2011 10:27 PM
either spun prop hub or bad engine coupler... I hope for your sake it's the spun prop hub.
Captainmatt87 09-07-2011 03:20 PM
Same thing happened to me. For me it's the coupler. But the only problem besides the $500 part is how do you pull the 7.4 out of a 252z Mariah?
Matt
mariah bob 09-14-2011 12:55 AM
spun prop. happened to me. looking at it you cant tell
kruthes1 09-16-2012 02:22 PM
Im betting its the coupler. Not a fun job. I did one in a Glastron with a 454/bravo 1. All of the rear interior had to be taken out. Good news is that the motor doesnt have to be completely removed. Most things can be left intact, you just have to pull motor mounts loose and remove bolts the bolts on the rear of the motor to seperate it from the transom. The motor has to be supported obviously and moved forward about six inches. Just enough room to get your hands in there and remove the bolts that hold the coupler to the flywheel and remove/replace. crappy job but better than paying the $2500 i was quoted just for labor.
aubtiger 09-16-2012 09:19 PM
I bet it is a spun prop. Put into gear (not running and out of the water) and turn your prop. if the prop spins free and the drive nut does not turn its the prop.
mikeyt 09-16-2012 11:06 PM
It will be interesting to hear if zzzino1 ever got around to fixing the problem and what the results were.
btw...my bet is with the coupler. Even a spun prop can still push the boat forward a bit unless the hub is completely destroyed.
