Throttle Cable Adjustment???
Hello,
I have a Mariah 200 with a 5.7 Mercruiser Alpha One Gen 2 and I recently had a new lower unit installed about 2 weeks ago and it only has about 4 hours I've put on it. The cable was adjusted right after installation. Everything has been shifting and working great. When I took it out today it would still shift into forward and reverse but when I put the shifter into neutral position it stays in gear and does this going out of forward and reverse. My question is, could the throttle cable need adjustment since because the new unit is being broke in?????? If so is it hard to adjust? I would appreciate some advice! Thanks |
| All times are GMT. The time now is 10:32 AM. |
