throttle issues
Just had Carb rebuilt and i still have the problem of when i hit the throttle is bogs and wants to die but then it picks up and seem fine. Any ideas
Re: throttle issues
Jim |
Re: throttle issues
It did not. Thanks . I will look into that.
Re: throttle issues
Re: throttle issues
Supposedly it was the accelerator pump was done also. I am taking it back to the guy who did it. Thanks for the help.
Re: throttle issues
Just so you understand: I'm saying the symptoms are those of a non-functioning accelerator pump. I'm not saying it is a non-functioning accelerator pump. I also noted two other causes for the same symptoms.
I'm just clarifying this before you get into a heated argument with the guy who rebuilt your carb :) Jim |
| All times are GMT. The time now is 01:20 PM. |
