What Carb do I have?
Hey there, After diagnosing a fuel problem I found out that the carb is full of crap and now needs to be rebuilt. The problem is I cant find numbers on the carb , only one stamped on top that says 8822. I have a 1992 Z198 Shabah with the 350 magnum. If anyone out there can help with what Carb I have so I can get a rebuild kit for it. I found out one thing though, NEVER buy a boat from a freind that says it was in perfect condition 3 years ago when it was last used... :rolleyes: . Thanks again in advance!
Re: What Carb do I have?
Ok, I see that I have a Weber 4bbl. The thing I cant understand is the numbers. The stamping on the base says 97708 0492. I cant seem to reference this anywhere. I see numbers for 9770 and 9770sa. Are these all grouped together as the same carbs? Even a better question , does anyone know people in the Toms River, NJ area that rebuilds Carbs.. Thanks!
I recently did some carb work and a local boat shop was able to tell me what carb I had by just knowing the year and size of my motor. Kits for mine were pretty pricey so I ended up just ordering the parts that I knew I really needed. GL with the project.
Its hard to find the #'s because they are actually mercruiser part #s in many cases I just went thru this.
| All times are GMT. The time now is 01:45 PM. |
