speedometer reading zero
clog in small hole at leading edge of bottom of outdrive.
inch or two above prop shaft I thought at first it was a chip in case, but was clogged hole work out stuff with stiff wire depth is about a standard drill bit deep speedometer seems to show 40 with about 40 lbs pressure perfect tool is 30 # freon bottle with air hose and blowgun with a rubber tip pull loose tubing inside held with a wire tie in dead center behind motor small brass fitting attach some tubing here to blow out outdrive section apply air to tube to test speedometer cleared hole, speedo works I just floated in water with boat lifted above water while rodding out mariah sx19 03 mercruiser alpha |
| All times are GMT. The time now is 10:08 AM. |
