-   -   Manual to Electric Choke - New Edelbrock 1409 (http://www.mariahownersclub.com/forum/mercury-mercruiser/4036-manual-electric-choke-new-edelbrock-1409-a.html)
dakotaman728 05-10-2010 12:54 AM
I just bought an Edelbrock 1409 marine carb with electric choke. My stock weber 9600 is manual choke so I was wondering how hard it will be to wire in the electric choke. Has anyone done this before?
The linkages on the Edelbrock and Weber carb are exactly the same so if i need to i could install the manual choke linkages on the edelbrock.
WetWilly 05-11-2010 06:19 AM
Re: Manual to Electric Choke - New Edelbrock 1409
Hi dakotaman728, on cars, we would just connect the chock wire to any ignition on power wire. I'm sure you could do the same with your mariah as well.
Or why don't you contact Edelbrock directly for advice, you should have their contact numbers in the carb literature, they've been very helpful to me in the past!
Good luck,
dakotaman728 05-12-2010 01:21 PM
Thank you for the input! I just found some good information on the interent.
