Outdrive Trim Sensor & Trim Limit Switch Replacement
Hi everyone,
It seems like we're getting more members experiencing up-trim issues. I found what I consider is a great article from Sterndrives.com on the trim sensors & trim limit switches located on your outdrive. It covers symptoms, theory of operation, a detailed description and a comprehensive writeup on replacing the trim sensor and trim limit switch, including some of the special tools you'll need. Even is you don't have a problem, it's good reading! Click here WetWilly |
| All times are GMT. The time now is 03:14 AM. |
