1993, 2350 Z dash instruments
I just bought a 1993 2350 Z. The clock, speedo and trim gauge don't work. Has anyone had the same problem and fixed it please?
Clive |
If you have Faria gauges, they offer a limited lifetime warranty. You send them your old gauges and for small fee they'll send you new ones.
Are you sure the problem with the trim and speedo are actually the gauges? The trim gauge is quite possibly a sender issue, and it might be worth it to clear out our speedo intake (on the outdrive) before you declare that gauge inoperative. |
Z202's thoughts are on the money.......and while you are at it, check to make sure the connections on the back of the gauges are secure and clean.
I'll take a look at the back of the gauges. Clive |
| All times are GMT. The time now is 01:05 PM. |
