-   -   Power Steering Pulley Replacement (http://www.mariahownersclub.com/forum/mercury-mercruiser/1535-power-steering-pulley-replacement.html)
DINKS Life 07-30-2008 11:01 PM
I have a 97 Talari Z216 with LX5.7 Closed cooled engine. The plastic pulley finally gave out. The parts guy at my marina sold me an up grade kit as the old 807728 pulley is no longer available. The new pulley is a 861578. The old pulley had a teeth on the inside to tie to the shaft. The new one has a smooth receiver. Am I missing a part or did they give me the wrong one? Thanks in advanced!
a
jmills224 08-01-2008 07:32 PM
DINKS,
I did a search for that part and it looks like they may have given you the wrong part. Part #807728T was superceded by part #807728-1. It is available here: http://www.boats.net/parts/detail/merc/M-807728T.html
The one you have may work. Then again it may not. Talk to your part supplier and see if they can get part #807728-1 for ya. If not you can always try online.
~J
adrumm00 06-15-2013 12:01 AM
Re: Power Steering Pulley Replacement
I need this same pulley and can't find it anywhere. It is no longer manufactured. Any suggestions?
ColoradoDiablo 06-15-2013 02:00 AM
Here ya go! :)
Carbed or EFI is same pulley.
It is 5 3/4" diameter
Count the grooves and head to the junk yard to find one:)
BTW...........Welcome to MOC!!
rhinoz 06-15-2013 02:01 AM
Here you go:
Link 1
