Help - alarm sounded
Took my 96 Mariah Shabah 4.3 Litre / Alpha One out after changing oil in the lower drive. I let it drain properly and filled from the bottom up, made sure it didnt leak. After driving it not far an alarm sounded so i shut it off. After looking at the engine I forgot to add oil in the reservoir tank. I topped it up to the line and took it for another ride and alarm sound still on ?? Any ideas why? :confused:
did you get all the air out of the system? it could be something as easy as needing to top off the reservoir again...i learned this the hard way:rolleyes:
brett |
Hey brett. So just leave the top off the reservoir and let it sit? Or should i take the reervoir tank off and clean it out ?? I check the air vent on the drive oil was coming out when I lowered the drive all the way down.
Ed:wink_thumbup: |
| All times are GMT. The time now is 11:19 AM. |
