-   -   1993 MX19 Mercruiser 4.3lx (http://www.mariahownersclub.com/forum/mercury-mercruiser/14320-1993-mx19-mercruiser-4-3lx.html)
matt123 08-07-2022 12:07 AM
Hi, Everyone, im having this issue, when i hit 4500 RPM they start to surge up and down and back fires, I currently, have a 4blade 19pitch prop i hit top speed of 35-37 MPH on GPS this is at 4400RPM. any help would be appreciated, i did change a fuel line today because it was kinked going into carb but that did not solve the problem.
mikeyt 08-07-2022 02:13 AM
Re: 1993 MX19 Mercruiser 4.3lx
Your prop should be fine with that engine / boat and you should get into the low-mid 40's with it. The surging / backfiring is usually due to running lean but it may be time for a carb rebuild.
matt123 08-09-2022 11:22 PM
Hey, Thanks for the input, im gonna try that and ill let you know how it goes.
GregT 08-10-2022 12:37 PM
check your fuel filter also, that could be the cause of running lean if it isn't getting the gas it needs due to junk in the filter.
Lennie 08-11-2022 09:26 AM
I have an 18' Diablo with the 3.0L Mercruiser and i was able to hit 4,500 RPM but now I'm lucky if it hits 4,000, full throttle is sounds like i have the anchor down, engine is struggling. Happened all of a sudden too.
