-   -   2000 mercruiser not trimmimg up but will trim down. (http://www.mariahownersclub.com/forum/mercury-mercruiser/13000-2000-mercruiser-not-trimmimg-up-but-will-trim-down.html)
MPITTMAN 07-26-2020 11:15 PM
I replaced upper solenoid and it worked fine over the weekend then when i returned home it quit. it will trim down on all switches but will not trim up. Crossed upper solenoid to make sure it wasnt motor and it worked fine. Not sure whats next besides replacinig solenoid again.
mikeyt 07-26-2020 11:53 PM
Re: 2000 mercruiser not trimmimg up but will trim down.
Read this STICKY
MPITTMAN 07-27-2020 06:29 PM
Checked both upper solenoid and switch on lower unit and both had continuity!!
MPITTMAN 07-27-2020 06:38 PM
Mikey please call 7314131638
mikeyt 07-27-2020 07:24 PM
I dont make house calls. Continuity is one thing, voltage at the solenoid is another. Check to make sure you have voltage at the correct solenoid as per the instructions when the trim switch is depressed.
Yiannis1380 06-06-2021 04:58 PM
I know this is late, just saw it. Had same issue, turned out one of my cylinders had an internal blown gasket. I rebuilt it and worked fine.
