Listing (porting) problem
Hello dear all. I am the new owner of a davante 215. I having listing problems on my left side when the boat is on cruise. When still no problems. The engine is a merc 260 with a bravo 1.
Recently i tried removing the wale tale and i installed the smart tabs to see if my problem will be solved. But no. Still the same issue. I do not have weight balance problems. A friend suggested that it might be due to the impeller suction on the right side. ( Its not on bravo its on the boat sticking out a little bit) do you have any ideas ? Thxxx |
Re: Listing (porting) problem
Bravo 1 is a single propeller the torque of the motor is twisting you to Port. Try moving your port smart tab down one click.
Sent from my XT1254 using Tapatalk |
I have tried one click difference with no luck. What positions do you suggest?
Keep experimenting until you achieve the results you desire. Every boat is different. I have a Z280 with hydraulic trim tabs and am constantly playing with the trim
| All times are GMT. The time now is 10:29 AM. |
