-   -   Knocking Noise (http://www.mariahownersclub.com/forum/mercury-mercruiser/12296-knocking-noise.html)
bisham 04-21-2019 01:49 PM
Knocking Noise
PROBLEM SOLVED. SEE BELOW. I have a 2001 Miriah Z275 Shabah with a 454 Mag MPI Generation VI.
Have a loud knocking noise. What does an exhaust leak sound like? Someone inside the engine hitting it with a hammer every second?
Here is a link to the noise:
https://www.youtube.com/watch?v=QzJd...ature=youtu.be
Could an EXHAUST LEAK make this sound?
SOLUTION:
It was an exhaust leak. If you ever need to replace your exhaust manifold, risers and elbows on a 454 Mag MPI, do NOT use GLM parts. We put GLM's on ours last year when we did a valve job. Turn out that the exhaust surface area on GLM exhaust systems does not have enough meat to make a good seal. There was one area where only about 1/16" was sealed between the manifold and the head. Also, I ordered a "Stock Mercury Replacement" from a place where we purchased a stainless steel sea water pump, and they shipped us another set of GLM's that I am returning. If you search for new 454 Mag MPI exhaust find the "Quicksilver" brand so you are getting actual Mercruiser parts. They will cost a little more but you will avoid reworking your engine because of the crap GLM manifolds.
Hudson River Steve 04-23-2019 10:54 AM
Re: Knocking Noise
Unfortunately that's no exhaust leak. It sounds like a rod bearing which is a death sentence for your motor. Better get it checked out by a pro.
Tlolesen 04-23-2019 11:39 AM
Re: Knocking Noise
Doesn't sound like any exhaust leak I ever heard sounds internal not good 😫
bisham 04-23-2019 02:35 PM
Re: Knocking Noise
My thought was it sounds like it only does it on one stroke. If it was a rod bearing I would think the noise would be on both the intake and exhaust which would be a faster knock. Does that make sense?
Hudson River Steve 04-23-2019 03:21 PM
Re: Knocking Noise
It does. Could be a valve that stuck and bent a push rid.
