Vibration when outdrive trimmed up
Old 07-17-2017, 08:06 PM   #1
Luecke83's Avatar
Luecke83 is currently offline
My Model: 182 Barchetta
Gallery Images: 4
Send Luecke83:
Question Vibration when outdrive trimmed up
I bought a 1995 Barchetta 182 with the 4.3L and Alpha 1 this spring. The boat has been awesome all summer until this last weekend. There were 4 of us cruising across the lake when I started to pick up a vibration. I was running around 30-35 mph and around 3800 rpm. I didn’t hit anything and was in 25-30 feet of water. I slowed down a little and it got worse. I trimmed the outdrive down and the vibration went away. I slowly gave it more throttle and was fine until I trimmed up and the vibration got worse. So I slowed down again and trimmed the out drive back down. We were able to run around 25 mph, trimmed almost all the way down, back to the dock and loaded up. The vibration didn’t seem to change any while turning. My first thought is gimbal bearing but before I order parts and pull the outdrive off I thought I would ask if anyone else has ran into this problem.
  • Old 07-17-2017, 08:28 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Vibration when outdrive trimmed up
    Does it vibrate only when turning or both?
    John
    Old 07-17-2017, 08:59 PM   #3
    Luecke83's Avatar
    Gallery Images: 4
    Send Luecke83:
    Both, if it is trimmed up.
    Old 07-17-2017, 10:01 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Could be a loose u joint. You will need to pull the drive to inspect both the u joints and the gimbal bearing.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-21-2017, 03:35 AM   #5
    Luecke83's Avatar
    Gallery Images: 4
    Send Luecke83:
    I pulled the outdrive off tonight and everything looks good. The u-joints are tight and the gimbal bearing is smooth. I'm not sure where to look next.
    Old 07-21-2017, 04:51 AM   #6
    My Model: Z202
    Send Firestone:
    Going through a similar situation. Had vibration mainly turning. U joint and bearing are fine. He moved to power steering, uggg b.o.a.t.
    John
    Old 07-21-2017, 01:11 PM   #7
    Luecke83's Avatar
    Gallery Images: 4
    Send Luecke83:
    I was reading another guy had a similar problem. His vibration ended up being a misfire under load. He ended up replacing the cap, rotor, plug wires and spark plugs to take care of it. That's probably going to be the next place I look.
    Old 07-21-2017, 01:46 PM   #8
    My Model: Z280
    While you have the outdrive off closely inspect your coupler for wear on the splines and for evidence of the metal splines slipping. BTW, were the driveshaft splines well greased?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-21-2017, 02:55 PM   #9
    Luecke83's Avatar
    Gallery Images: 4
    Send Luecke83:
    The splines were greased well. I'll look again tonight but the splines look good on the drive shaft and in the coupler.
    Old 07-22-2017, 01:16 PM   #10
    Luecke83's Avatar
    Gallery Images: 4
    Send Luecke83:
    The splines in the coupler and on the shaft look good.
    Speedometer only working When motor is trimmed wide open WetWilly Original Mariah Talk 9 08-17-2021 01:29 AM
    Vibration on Maximum turning/steering woodward33 Mercury MerCruiser 9 08-04-2017 06:53 PM
    Trailer Vibration - Only at 35mph? Slash9point5 Trailering and Tow Vehicles 5 05-13-2011 05:15 PM
    Vibration in neutral yblockmike Mercury MerCruiser 1 03-31-2011 05:02 PM
    Vibration from Outdrive? dudders Mercury MerCruiser 10 01-13-2008 04:09 AM
    Total Members: 18,524
    Total Threads: 12,958
    There are 102 users
