-   -   2006 mariah motor (http://www.mariahownersclub.com/forum/mercury-mercruiser/10236-2006-mariah-motor.html)
my97camaro 06-16-2015 03:44 PM
2006 mariah motor
Couple of freeze plugs came out last winter, have checked oil looks good, do have a crack in the exhaust manifold. Cannot get water to cycle thru the engine, you can tell the exhaust manifold is hot but the temp gauge is not coming up either. Any clue what I need to start with? I've had this boat since 2008 and never had any issues. :confused:
cswinings 06-16-2015 04:02 PM
Re: 2006 mariah motor
What engine? I would probably start with the raw water impeller.
my97camaro 06-16-2015 04:13 PM
4.3 mercruiser I/o
cswinings 06-16-2015 04:27 PM
so that would have alpha 1, which has an impeller inside of it, rather than mounted on the engine, when that goes bad, and they do. Then no water gets pumped into the engine.
my97camaro 06-16-2015 04:53 PM
Awesome thank you will try that!
