-   -   starting issues (http://www.mariahownersclub.com/forum/introductions/9167-starting-issues.html)
mikstick 04-06-2014 05:02 PM
starting issues
I posted earlier about no crank issues.i just found my winterization receipt and my marina says I need a starter kicker solenoid.Can somebody explain to me what and where do I find this solenoid 0n my Mariah boat.i thinking they mean a starter solenoid.the engine on my boat is a 4.3 merc
mikeyt 04-06-2014 07:09 PM
Re: starting issues
You could just read the STICKY in the maintenance section for instructions & pics.
mmckenzie6 06-05-2015 11:57 PM
Re: starting issues
Picked up on an old thread here.
Followed Mikeyt instructions on the maintenance sticky. I get a click at the slave solenoid. Checked for voltage at Terminal A, and all good. Touch Terminal B while having assistant turn key. Solenoid clicks but no voltage at Terminal B. So bad solenoid according to sticky.
Purchase new slave solenoid and install. Exactly same result.
Any suggestions?
99 Mariah 258 06-06-2015 01:04 AM
Re: starting issues
Check your grounds... I had someone install a starter and he didn't tighten it all the way I guess and it had oxidation between the starter and the block and it wouldn't ground properly. Also went ahead and put all new connectors on the main cables (big ones) and all the smaller connectors on the solenoids..
mmckenzie6 06-27-2015 02:03 PM
Re: starting issues
Final verdict: bad Mallory fuse.
