Re: My Introduction
Re: My Introduction
Evening Mikey :rolling_laugh:
Defo prop hub. If it's a rubber hub then even though it's spun you'll have trouble turning it by hand. If it's a flo-torq it'll just be trashed.....that's what they are there for. Anything else would have other results as listed above like noise, vibration or smell of rubber under the hatch |
Re: My Introduction
How expensive/and how difficult is that to repair?
Thank you so much for your insight. Is there a way that I can test for that with the boat being out of the water? I hope this isn't going to be a really expensive repair. I would love to get her back in the water this year. You have no idea how much I miss quality time with my Mariah. |
Re: My Introduction
If its a rubber hub it will likely have to be pressed out and a new one pressed in but if its a Flo-Torq or a Michigan Wheel XHS style then its very easy to change. Maybe $75 for the rubber style and $50 for the Flo-Torq/XHS style.
Again, i'll suggest that if you have a buddy with a similar outdrive/prop then borrow his and try it to see if it makes a difference. |
Re: My Introduction
UNfortunately I don't. Where I go boating, it's mostly ski boats or pontoon boats. I think I've only ever seen one other Mariah on the whole river.
How do I identify which one mine is? Also, according to the Smart Tabs video, my boat is too big. Does that matter? They sure seem like a great idea. |
Re: My Introduction
Ohh they make them for your Z209 RA. :wink_thumbup:
Smart Tabs SX Trim Tabs Also have the stainlees steel ones if you want http://www.nauticusinc.com/smart_tab..._trim_tabs.htm |
Re: My Introduction
You also might want to take a couple of minutes and read my STICKY in the Prop Talk section for some insight on props. |
Re: My Introduction
Thank you for a fantastic reply. I'm very appreciative of your help and your patience. I figured that the prop probably isn't ideally suited to the boat, but the previous owner put it on and they're expensive to replace. One thing's for sure, she jumps out on plane in a hurry.
It occurred to me that the gas has been in the tanks since 2007 and probably isn't a good thing to run through the engine. Is there a way to drain it out other than a siphon? I believe that the tank is also aluminum, so corrosion shouldn't be a concern, correct? Does Mariah feature a drain for the tanks? If so, how do I access it? |
| All times are GMT. The time now is 04:36 PM. |
