-   -   hello new owner of 03 mariah sx19 (http://www.mariahownersclub.com/forum/introductions/7949-hello-new-owner-03-mariah-sx19.html)
rainman55343 04-12-2013 05:39 AM
Hello I'm a new owner of a 2003 Mariah sx19 with a 5.0 mercruiser carb. The last owner got this boat reposed from him. It doest look like it was taken of. Wood grain dash clear coat coming off bad which I probably will paint. Bad surge brakes on trailer found rust in master cylinder. Was not winterized but no water in engine thank god. Anyway lots more too. But I plan on changing oil filter gear oil tilt trim fluid. And water fuel separater filter carb filter plugs wires cap rotor.anything else that u can think of would help. Hopefully water pump and impeller are good. This is my first Mariah boat.thank you peter
ColoradoDiablo 04-12-2013 12:54 PM
Re: hello new owner of 03 mariah sx19
Welcome to MOC Peter! :)
Lots of great people here to help you with anything we can.
Congrats on your new Mariah!!
rainman55343 04-12-2013 01:16 PM
Thank you very much
mikeyt 04-12-2013 02:31 PM
Welcome aboard Peter. Given the poor maintenance you've noted elsewhere on the boat i would get the impeller changed out too. If that thing busts up you will likely end up with a blockage & an overheated motor.
rainman55343 04-13-2013 01:19 AM
I will thx
