Gas Gauge Fuse
Happy to be here---great way to find out information about Mariah Boats. I've been searching to see what type of fuse I need for my 1997 Mariah Jubilee gas gauge. The boat has so many fuses I didn't want randomly search. Can anyone help me on this. I don't like going out on the lake not knowing exactly how much gas is left in the tank. Thanks for any help you can give!
Re: Gas Gauge Fuse
Are you sure its the fuse? Usually it is a loose/broken connection or a corrosion issue at the fuel sender unit. If you do a site search for "Fuel Sender" you will find numerous threads on the subject.
| All times are GMT. The time now is 04:41 PM. |
