Tilt problem
Hello....I am new to this site, but I purchased a 1993 Mariah Talari in November 2011. I am having trouble with the outdrive tilt coming up. When I push the down button the outdrive will go down, but doesn't make a sound, or move when I push the up button.
Any ideas? Also....how can I get a owners manual to know about all the equipment my boat has. I would like to get repair manuals for the engine and outdrive as well. I would very much appreciate any information. Thank You, |
Re: Tilt problem
The outdrive may not be down enough for the "Trim" button to activate in the up position. Try the "Trailer" button. The "Trm" button only goes up so far to save the outdrive gears. The "Trailer" button raises it farther for transporting.
Re: Tilt problem
A litte site search regarding your questions about manuals etc would give you the answers you seek. Check out our FAQ's and / or either of these stickys located at the top of the Introductions forum covering manuals and the Benefits of Becoming a Contributing Member.
| All times are GMT. The time now is 02:49 AM. |
