-   -   cobra omc 4.3 liter (http://www.mariahownersclub.com/forum/introductions/6635-cobra-omc-4-3-liter.html)
ceedercreakmcbride 04-06-2012 07:45 PM
cobra omc 4.3 liter
Having problems with my boat backfiring through the carburetor I can't figure it out. I don't know if it's the coil pack for the ecm any and all help welcome please contact me via email or pm. wink_thumbup:
mikeyt 04-07-2012 12:48 AM
Re: cobra omc 4.3 liter
There can only be one cause for backfire in 4 stroke engines; timing of the valve and ignition. Think about it... when the spark occurs and the intake valve is open to ignite the fuel in the intake manifold it "backfires" through the carb.
Let me say it more directly; IF valve timing is correct and the ignition timing is set correctly it is impossible to get carburetor backfire because there is no ignition source to ignite the incoming fuel.
The only other thing i can think of that might contribute to the above is a stuck float in the carb.
jarwiebe 04-07-2012 01:00 AM
Hi ceedercreakmcbride
Here is a link to some common reasons for engines to backfire and some suggested remedies.
What is Car Engine Backfire Through the Intake or Exhaust - 2CarPros
Hope this is helpful
