-   -   1996 Mariah Shabah 200 oil change (http://www.mariahownersclub.com/forum/introductions/5275-1996-mariah-shabah-200-oil-change.html)
nrwhitek 03-26-2011 02:43 AM
I want to change my oil on my 96 Shabah. Is it hard to do? What oil do you recommend and how many quarts? Does it have a drain plug or do I need to pump out the old oil through the dip stick?
Thanks for your help!
Nathan
mikeyt 03-26-2011 03:14 AM
Re: 1996 Mariah Shabah 200 oil change
Changing the engine oil is reasonably easy with an electric marine oil extraction pump and i use Sierra 25w-40 marine engine oil myself. If you figure you can do it by draining thru the sump have a look down there. There isn't much room and it can be very messy. What motor do you have? A 5.0 & the 5.7 both take 5 1/2 US quarts.
mariah bob 03-26-2011 04:39 PM
I agree, use the pump. I change mine every season and use Moblile One. I have the 5.7
1999Mariah 03-26-2011 04:46 PM
Any input on the 3.0 for a 180 Shabah, tips / advice....Tutorial!? :)
nrwhitek 04-05-2011 04:45 PM
I have the 5.7. Thanks for all the feedback. I plan on changing the oil this weekend. :wink_thumbup:
rajjneef 04-05-2011 09:28 PM
I would say use a manual pump unless you are buying one of the very expensive electric ones. Every service shop i've seen uses manual pumps. A decent manual pump will cost you about $50.
scubydo 04-08-2011 12:49 AM
I use the Mercuriser hose that bolts in where the oil plug is. you just stick the hose down through the Transom drain plug opening, and it drains all the oil out in about 15 minutes. The hose was about 60 dollars at a local stealership, but online they are only about 20-30 dollars. . No mess, I love it.
mikeyt 04-08-2011 01:16 AM
Originally Posted by scubydo (Post 28258)
I use the Mercuriser hose that bolts in where the oil plug is. you just stick the hose down through the Transom drain plug opening, and it drains all the oil out in about 15 minutes. The hose was about 60 dollars. No mess, I love it.
I'm not sure i've seen one of these. Got a pic or a link to one? Does it stay connected with some sort of valve or ??
scubydo 04-08-2011 07:31 AM
Here is a link to the Oil drain hose kit. It stays connected all the time, My kit came with a little hanger to hang the end of the cable up above the Oil pan. Very sweet setup, no mess at all,
Oil Drain Kits Marine Engine Parts & Fishing Tackle - eBasicPower
