1998 Mariah 246 talari
Hi, I just purchased a 1998 246 talari, and would like some info on the control switches on the dash, in particular the two located on each side of the ignition switch, i do not know the correct function of these. I would appreciate any help. Thanks, Joel
Re: 1998 Mariah 246 talari
front and rear navigation lights the green red (if dials) the second one is my blower switch
My '99 Z212 Shabah has the blower and horn just to the right of the ignition. I assume your switches are faded? Maybe a picture could help us identify.
Thank You, The one to the left of the ignition switch is the blower switch for sure, the problem is they are faded, I just recently purchased the boat and the previous owner did not take good care of it, it's only got 48 hrs on the boat and motor, it just has alot of cosmetic problems that i'm in the process of restoring.
Ok, i will upload a photo, thanks for the help! also yesterday we took the boat out for the first test run and my fluid resivoir for the bravo 3 outdrive overflowed some, any feedback on this? I did some reading and will check to see if there is a gasket on the cap, and I also read about the speed shower kit, any feedback on this kit? Thanks, Joel
| All times are GMT. The time now is 05:37 PM. |
