-   -   mariah going to be fish food help (http://www.mariahownersclub.com/forum/introductions/2651-mariah-going-fish-food-help.html)
boat man2 06-03-2009 04:47 PM
bought a 1994 talari 210 with new 5.0L and new out drive and takes about 30-45 second to plane out wot 4800 rpm and about 43mph with a 19p high five any help before this mariah becomes fish food:confused::confused::confused:
indykoch 06-03-2009 04:54 PM
Re: mariah going to be fish food help
This one's tough! I have to think something isn't tuned correctly. Your RPM's are about right, meaning the pitch should be about right. But it has a high five which will give lower top end (which we're seeing) but a better hole shot (which we're definitely not seeing). I can't help but think there's something wrong with the engine, carb, drive alignment, maybe even water-logged stringers/transom adding weight.
I hate to say it, but a good surveyor or mechanic should be able to help. I don't totally count the prop as the culprit just yet. Either way, it's a Mariah - DO NOT turn it into fish food. You'd have about 2000 angry Mariah fanatics after you!!!
boat man2 06-03-2009 05:03 PM
just had the engine and out drive replace last july . i thought it was not tunned right also and took it back but it is no water bought the boat from my grandfather and has been stored in side ,takes on no water at all once you get out of the hole it runs ok for the altt. we are at i think
