-   -   New owner 18 ft Mariah 1993 (http://www.mariahownersclub.com/forum/introductions/2005-new-owner-18-ft-mariah-1993-a.html)
pull 01-17-2009 04:47 PM
HI i just bought a 93 - 18ft bowrider in the fall . It has the 4.3 v6 motor my mechiac has it running real well it seams very fast . I would like to wakeboard with the boat . I installed the stingray hydrofoil on the outdrive and she comes rite up on plane nicely. I plan to install awakeboard tower on the boat and would love to hear some advice on doing this. also could you give me some feed back on a four blade prop for this set up thanks. Because I might have four or five adluts on board and want the right combination for this motor. Thanks for all your help. Pull
mikeyt 01-17-2009 10:41 PM
If you have a look under our 'Watersports' thread you should find lots of info about wakeboard towers. As for the hydrofoil, we've discussed this at length here numerous times. I'm not a fan of hydrofoils though and would tell you to install a pair of Smart Tabs instead. I run a 4 blade 20" pitch SS prop on mine which works very well for wakeboarding.
