Please help. 1995 mariah talari 4.3l mercruiser cold start issues
Introductions
Old 05-27-2022, 04:20 AM   #1
Jeffyoung is currently offline
My Model: Talari
My Engine: 4.3l mercruiser
Send Jeffyoung:
Default Please help. 1995 mariah talari 4.3l mercruiser cold start issues
Hi everyone I am a new mariah owner. I am having some issues starting my 4.3l mercruiser from cold start. I have been running throttle only and pumping 5 or 6 times then pulling back halfway. Start cranking and it fires up but no matter where I place throttle it will run for 10 seconds and die. The only way I have been able to get it to start and stay running is by dumping a small amount of fuel in the carb once I do this it starts and stays running. When shut off after initial start it will always fire right back up. Am I doing the cold start sequence wrong should I be pumping more first? Seems as if it runs out of fuel but I have pumped 25 times and it still won't start initially unless I dump fuel in the carb. Or could this be a choke issue such as it not opening properly after initial start and choking itself out? Any help would be greatly appreciated.
    cold start 3.0 carb midwest mariah Mercury MerCruiser 12 07-03-2020 12:41 AM
    1995 talari steering issues don swartz Introductions 4 11-03-2017 09:43 PM
    Hard to start when cold griffin Boating 101 17 05-19-2015 06:12 PM
    Where is the starter? 1995 Talari 454 Mercruiser SOFTTAIL1999 Original Mariah Talk 4 11-29-2011 12:28 AM
    Cold starting my 93 1900Z Mercruiser 4.3L motoboy5207 Introductions 3 08-10-2010 12:03 AM
    Total Members: 18,508
    Total Threads: 12,950
    There are 143 users
