New member. Need help.
2 Attachment(s)
I have a 1994 1900Z and i cant figure out where the gas tank is. Im sure the pickup tube is rotten because at 3/4 tank the boat surges bad. I need to figure out the ASV size to order one. If it has one. Its a 5.7L mercruiser alpha one. 21ft. Can anyone point me in the right direction?
Re: New member. Need help.
Its underneath the floor in front of the motor. Should be a little flap there (under the carpet) that allows you to access your fuel sender unit. Once found, you've then found your fuel tank.
Oh ok thank you! That helps me a lot!
| All times are GMT. The time now is 12:03 PM. |
