New Member
Enjoying our “new to us” 1992 Z1900.
Just put “smart tabs” on. I have them set in the #3 position A couple questions. Do you run the power trim on the outdrive in the full down position when I am cruising between between 25-30 ( I feel I’d like a bit more hull out of the water than I do at this setting) Can you adjust the side to side list on the boat by moving the positions on the tab? Thanks in advance everyone! |
Re: New Member
I would allow the outdrive to trim out a bit. The tabs will counter-act it but it should lift the front end up so that it doesn't plow. I have one of mine set in the #2 position and the other in the #3 position to offset the slight list that my boat had. Seems to work.
| All times are GMT. The time now is 11:48 AM. |
