-   -   How to compare Mariah boats? (http://www.mariahownersclub.com/forum/introductions/12938-how-compare-mariah-boats.html)
Triquetra1971 07-06-2020 02:58 PM
Greetings,
I am wondering how to compare the different versions of Mariah boats? I am looking for a bow rider that I can pull wake boarders with and enjoy. I know enough to know that Mariah boats are AWESOME!!! But how does the Talari compare to the SX to the Shabah from a performance standpoint? I mean, other than a bigger motor and a different outdrive I don't know how to compare the boat line for performance. I'd also like at least a 22' foot to 25' boat. If that matters?
Thank you
mikeyt 07-06-2020 07:01 PM
Re: How to compare Mariah boats?
A 'Shabah' and a 'Talari' are part of the original Mariah built boat lineup built from 1990 - 2002. The "SX" is one of the Sea-Fox built boats with the Mariah name on it built from 2003 - 2013. The original Mariahs had much better construction. The performance levels are all similar given the same motor / outdrive combination. A 20' - 22' boat with the 5.7L and a 4 blade SS prop will give you all the pulling power you need.
