Inboard engine wont go down
My inboard engine wont go down. Not sure why or what I may be doing wrong
Re: Inboard engine wont go down
My first guess will be one of the two outdrive solenoids has failed. They are located behind your rear seats usually on the port side. Here is a link to a troubleshooter that should help confirm the cause of your problem and guide you in fixing it. Read it all the way through first before you start poking around back there. --> http://www.mariahownersclub.com/foru...or-system.html |
| All times are GMT. The time now is 04:05 PM. |
