New Member Boat Trailer question
Introductions
Old 01-08-2019, 05:07 PM   #1
billyfitz is currently offline
My Model: Jubilee
My Engine: 310 Mercruiser
Send billyfitz:
Default New Member Boat Trailer question
I am buying a 98 Mariah Jubilee 24' from a friend but he has had it in a slip and does not have a trailer for it. Everybody says "it's easy to find a use boat trailer" but I'm finding that not to be the case because of the variables. Is it necessary to find a trailer made exactly for this boat shape or one that is relatively close be OK?
  • Old 01-09-2019, 03:49 AM   #2
    Default Re: New Member Boat Trailer question
    Welcome billyfitz! You're correct, finding an original Chariot trailer for the Jubilee 244 will be close to impossible. Most bunk trailers are adjustable with u-bolts and brackets that can be moved around on the trailer frame, so it could be modified to fit the Jubilee hull. Most marinas/marine service shops should be able to assist with getting it properly set up. You definitely would want to have any adjustable trailer fit properly so it doesn't cause any damage to the hull chines or gelcoat while underway.
    Hope this helps!
    Old 01-11-2019, 12:54 PM   #3
    Towers1538 is currently offline
    My Model: 182
    My Engine: 4.3L
    Send Towers1538:
    BillyFitz,
    Don't know where you are located, but I found a 99 Jubilee for sale with trailer for $2500 (bad motor) in North Carolina. You can have a parts boat and a nice trailer. Check it out.
    https://charlotte.craigslist.org/boa...761960123.html
    Old 01-13-2019, 01:03 PM   #4
    Mwb712 is currently offline
    My Model: 182 Barchetta
    My Engine: MCM 4.3 Litre LX
    Send Mwb712:
    As long as it’s the right length and width should be okay.
    Sent from my iPad using Tapatalk
    Prestige trailer question SKMARTIN6 Trailering and Tow Vehicles 2 09-20-2012 05:22 PM
    Trailer Jacking Question newbie Original Mariah Talk 6 12-30-2011 08:32 PM
    New member with new boat needs help with trailer switch !! johnpearce Original Mariah Talk 1 09-01-2011 12:18 AM
    trailer question rico Trailering and Tow Vehicles 1 06-10-2011 05:13 PM
    trailer needs repair/ question??? Lakeside Trailering and Tow Vehicles 6 05-19-2011 12:25 PM
    Total Members: 18,525
    Total Threads: 12,958
    There are 201 users
